SteelerNights
Oct 07, 2025Guide
RS600 dropping connection, rebooting randomly...
I've had this RS 600 and it's been terrible. Very inconsistent wifi speeds, I tried manually changing channels, and the 5g line kept dropping out. Then today, the entire router crashed and was ...
SteelerNights
Oct 07, 2025Guide
Also, I just checked and all logs associated with the event, are gone. Only log that exists is after the router re-initialized, this makes it impossible to understand what went wrong.
Oct 07, 2025Guru - Experienced User
Try a factory reset and setup from scratch with a wired PC and web browser?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Is IPv6 and Protection Engine enabled on the router? If so, disable both.
