SteelerNights
Oct 07, 2025Guide
RS600 dropping connection, rebooting randomly...
I've had this RS 600 and it's been terrible. Very inconsistent wifi speeds, I tried manually changing channels, and the 5g line kept dropping out. Then today, the entire router crashed and was ...
Oct 09, 2025Guru - Experienced User
Try a factory reset and setup from scratch with a wired PC and web browser?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Is IPv6 and Protection Engine enabled on the router? If so, disable both.
- SteelerNightsOct 09, 2025Guide
I did a factory reset - I don't have any laptop with an ethernet port. But I did do this.
I'm with Verizon Fios, and there's an ONT in the garage I couldn't find a model number on it, however, Google Gemini says it's a Nokia I-211M-L
- FURRYe38Oct 09, 2025Guru - Experienced User
Thank you for the ONT info.
Seen some historical posts with NG routers and some ONTs before.
There are some known issues with IPv6 and NG routers as well. Also ISPs are involved as well. NG is aware of this.
I recommend keeping in contact with NG if you have already opened up a support ticket. I've also past your post onto NG as well.
Also if Protection Engine is seen on your router, then NG recommends disabling this feature as well.
FW versions can be posted if you didn't sign an NDA or was told by NG not too.
