Retired_Member
Feb 06, 2026RS600 latest version, 1.0.6.16 IoT network works like a Guest Network
Well, I got all excited about the new IoT network capabilities in 1.0.6.16. I moved a couple of devices to the new IoT network, and they connected to the internet. Then connected my phone to the IoT ...
Feb 09, 2026Guru - Experienced User
IoT network is working on my RS700. Connected two wireless PCs on it and can connect in between them. If I put one PC on the main LAN via ethernet, still can connect to wireless PC on the IoT Network.
- coolwifiFeb 09, 2026Virtuoso
That's good to know. I have been using a separate 2.4 Ghz SSID and same 5 / 6 Ghz SSID's. I am unable to control my soundbar connected to the 5 Ghz band sometimes, but restarting the device fixes it. I will move it to the IoT network and see.
