Retired_Member
Feb 06, 2026RS600 latest version, 1.0.6.16 IoT network works like a Guest Network
Well, I got all excited about the new IoT network capabilities in 1.0.6.16. I moved a couple of devices to the new IoT network, and they connected to the internet. Then connected my phone to the IoT ...
Feb 09, 2026Guru - Experienced User
IoT network is working on my RS700. Connected two wireless PCs on it and can connect in between them. If I put one PC on the main LAN via ethernet, still can connect to wireless PC on the IoT Network.
coolwifi
Feb 09, 2026Virtuoso
That's good to know. I have been using a separate 2.4 Ghz SSID and same 5 / 6 Ghz SSID's. I am unable to control my soundbar connected to the 5 Ghz band sometimes, but restarting the device fixes it. I will move it to the IoT network and see.
- FURRYe38Feb 09, 2026Guru - Experienced User
Let us know how it goes. Main WLAN is using Smart Connect here. Manual channesl 11, 48 and 37.
IoT network is using both 2.4 and 5Ghz with PSK2 set for both.
- coolwifiFeb 09, 2026Virtuoso
I can control IoT devices from my main WLAN in my RS500 too!
I like to have a separate 2.4 Ghz SSID, as smart connect tends to connect devices to the 2.4 Ghz band first when the router is restarted. Wish NG had smart connect just for the 5 and 6 Ghz bands.
