anderpf
Feb 06, 2026Guide
RS600 latest version, 1.0.6.16 IoT network works like a Guest Network
Well, I got all excited about the new IoT network capabilities in 1.0.6.16. I moved a couple of devices to the new IoT network, and they connected to the internet. Then connected my phone to the IoT ...
CrimpOn
Feb 10, 2026Guru - Experienced User
anderpf wrote:added my WiiM amp to the 2.4G IoT and then put my iPhone on the IoT network
Was the IoT network active on both 2.4G and 5G during this test? Some smartphone apps do not function correctly when the phone is connected at 5G.
Does the WiiM amp respond to ICMP (ping) ?
Thank you for bearing with us on this. It is just so strange that users have tested both the RS500 and RS700 and found that they both handle the IoT network as expected.
