Retired_Member
Feb 06, 2026RS600 latest version, 1.0.6.16 IoT network works like a Guest Network
Well, I got all excited about the new IoT network capabilities in 1.0.6.16. I moved a couple of devices to the new IoT network, and they connected to the internet. Then connected my phone to the IoT ...
Retired_Member
Feb 18, 2026So the last week, I put 5 Roku streamers and 2 Sony Bravia TVs on the 5G guest network, and they all worked great. After 2 days of harassment from the TVs (i.e. Google), I turned their WiFi off and just use the Roku streamers. Roku's work great on guest network. I checked with SimpliSafe, and they recommended put devices on the 2.4G guest network, and not on a system with smart connect (although I always keep my networks separate). So, the SimpliSafe hub and 5 cameras are all moved to the 2.4G guest network and working fine. I then went for the Ion System HVAC thermostat, also working great.
So that leaves me with a WiiM amp and Hubitat Elevation Z-wave hub. These two need a true IoT for setup and programming. So, until NG can figure out IoT for the RS600, which for me is communication to the internet and other IoT network devices only (could have an optional setting for main network that I won't use), this will be my network setups. My RS600 is a year old and don't want to spend the money on an Asus for these two devices.
Thanks for all the responses.
- coolwifiFeb 18, 2026Virtuoso
If you don't want to use guest networks, you could turn off smart connect and still have the same SSID's for all the wifi bands. The 2.4 Ghz band security could be set to WPA2-PSK for full compatibility.
- FURRYe38Mar 16, 2026Guru - Experienced User
Retired_Member
Any progress on this? Please let us know...
