Retired_Member
Feb 06, 2026RS600 latest version, 1.0.6.16 IoT network works like a Guest Network
Well, I got all excited about the new IoT network capabilities in 1.0.6.16. I moved a couple of devices to the new IoT network, and they connected to the internet. Then connected my phone to the IoT ...
Retired_Member
Mar 16, 2026I was asked to install a trial firmware version V1.0.6.20. When I asked what the functionality would be "Starting from Trial firmware version V1.0.6.20, the IoT network and the main network are connected. Devices on both networks can see and communicate with each other". Because I don't want the IoT and the main network connected, I won't be installing it as it provides no benefit over putting IoT devices on the main network. If NG provides a selection to isolate the IoT from the main, then I'll use it.
Mar 16, 2026Guru - Experienced User
You might try the FW to see if having devices connected on the IoT network can connect to each other on the IoT network.
anderpf wrote:I was asked to install a trial firmware version V1.0.6.20. When I asked what the functionality would be "Starting from Trial firmware version V1.0.6.20, the IoT network and the main network are connected. Devices on both networks can see and communicate with each other". Because I don't want the IoT and the main network connected, I won't be installing it as it provides no benefit over putting IoT devices on the main network. If NG provides a selection to isolate the IoT from the main, then I'll use it.
