cliff344
Nov 05, 2025Apprentice
RS600 new firmware issues 1.0.5.22
Downloaded and installed latest FW release 1.0.5.22, and now experiencing issues with internet dropping out for about 30 seconds every 10-15 minutes. This was most prevalent on the ethernet side, but...
Nov 06, 2025Guru - Experienced User
Does the Internet LED on the front turn AMBER or RED when this happens?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Using ISP detected DNS or custome DNS?
Is IPv6 and Protection Engine enabled on the router?
- cliff344Nov 07, 2025Apprentice
Yes it intermittently switches to red. I know it os a router issue as I replaced with my old router and not any problems.
I does also show in router logs of disconnect. Happens as much as 2-10 times per hour for just a short time of about 20-30 seconds then reconnects.
Internet LED turns red during disconnection
- FURRYe38Nov 08, 2025Guru - Experienced User
Means the router has lost connection with the modem
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? We need this info please.
Factory reset the router and setup from scratch.
Trying using Cloudfare or Quad 9 IPv4 DNS addresses.
Leave Protection engine disabled.
I've had my RS600 online for days with out seeing this on this version of FW.
