cliff344
Nov 05, 2025Apprentice
RS600 new firmware issues 1.0.5.22
Downloaded and installed latest FW release 1.0.5.22, and now experiencing issues with internet dropping out for about 30 seconds every 10-15 minutes. This was most prevalent on the ethernet side, but...
Nov 06, 2025Guru - Experienced User
Does the Internet LED on the front turn AMBER or RED when this happens?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Using ISP detected DNS or custome DNS?
Is IPv6 and Protection Engine enabled on the router?
cliff344
Nov 07, 2025Apprentice
I does also show in router logs of disconnect. Happens as much as 2-10 times per hour for just a short time of about 20-30 seconds then reconnects.
