cliff344
Nov 05, 2025Apprentice
RS600 new firmware issues 1.0.5.22
Downloaded and installed latest FW release 1.0.5.22, and now experiencing issues with internet dropping out for about 30 seconds every 10-15 minutes. This was most prevalent on the ethernet side, but...
cliff344
Nov 09, 2025Apprentice
Reverted back to previous firmware, still having issues. I removed the router all together and replaced with my previous RAXE500, which was working fine. Everything working well, so I have to assume the problem is the router and the updated firmware must have corrupted the router. Will try a factory reset and reload my Lan IP tables and try again. Otherwise I am going to assume this update killed it. Was working fine for months, before updating.
- FURRYe38Nov 10, 2025Guru - Experienced User
Could you please capture the debug logs from the routers IP address/debug.htm. Please check WAN/LAN packet capture as well. Let it run for 5 minutes then select the save logs button.
Put up on a cloud storage site like dropbox or onedrive and PM me the share link.
Will get this to NG.
