cliff344
Nov 05, 2025Apprentice
RS600 new firmware issues 1.0.5.22
Downloaded and installed latest FW release 1.0.5.22, and now experiencing issues with internet dropping out for about 30 seconds every 10-15 minutes. This was most prevalent on the ethernet side, but...
Nov 24, 2025Guru - Experienced User
cliff344
Nov 24, 2025Apprentice
Frontier XGS-PON-ONT. Model #FRX523. I used this ONT successfully with Rax200, and Raxe500, never a single bit of problem.
- FURRYe38Nov 24, 2025Guru - Experienced User
Ok. We've seen some odd issues with RS routers and ONTs over this past year. So needed to know what you have with the RS router.
Will pass this to NG for review.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-routerEnjoy. 📡
