hockeynut192
Apr 04, 2026Follower
RS600 not connecting
I have the same issue will work when hooked up to old router but not directly to modem. Did Netgear get you a solution?
Apr 06, 2026Guru - Experienced User
Whats not connecting?
Did you power off the ISP modem then back ON when you connected the RS router?
My RS600 is currently online with a CM3000 modem. Working good here.
hockeynut192 wrote:I have the same issue will work when hooked up to old router but not directly to modem. Did Netgear get you a solution?
