hockeynut192
Apr 04, 2026Follower
RS600 not connecting
I have the same issue will work when hooked up to old router but not directly to modem. Did Netgear get you a solution?
Apr 15, 2026Guru - Experienced User
Any progress on this?
New FW available:
NOTICE - RS140/RS200v1/RS280/RS500/RS600 Firmware Version 1.0.6.22 Released | NETGEAR Communities
hockeynut192 wrote:I have the same issue will work when hooked up to old router but not directly to modem. Did Netgear get you a solution?
