jimbomudgie
May 15, 2025Aspirant
RS600 Setup Problems
Hi, I am trying to set up a new Nighthawk RS600 but cannot seem to connect to the internet with it. I have a TPG HFC connection. I'm moving from an Netgear Orbi so I would think it should work. I co...
- Aug 08, 2025
Hi Jim
I hope this reply is not too late for you.
I bought a RS600 recently and had the same problem like you: TPG, CM8200B and RS600. I could not make the RS600 get the internet. Finally, I worked it out.
The solution is
In the webpage RS600 setup menu, choose BASIC-Internet then set
Require a login
Internet Port(10 Gbps)
PPPoE
your TPG username (doesn't need email format, just the name)
password
then leave all other as default
Then go to the bottom of this page, VLAN ID Configuration
Tap VLAN/Bridge Settings, enable VLAN/Bridge group, pick By VLAN tag group, EDIT AND make the VLAN ID to 2.
Apply the setting and hopefully, the RS600 should work.
May 15, 2025Guru - Experienced User
Does ISP use any specific WAN side configurations like VLAN or PPPoE or just DHCP?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure to set up the router using a wired PC and web browser: https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
- jimbomudgieMay 16, 2025Aspirant
Hi,
The ISP uses PPPoE. The ISP provides the Arris CM8200B modem. The cable im using is the new cable that came with the RS600 and I'm connecting the PC to it via the LAN port when changing the settings.
I haven't had a chance to sit down and follow the instructions you provided yet, but will update once I've done that. Thanks for the reply.
- FURRYe38May 16, 2025Guru - Experienced User
May need to use the routers web page to set up PPPoE configuration for the ISP service. Routers web page under Advanced tab/Setup/Internet.
Contact the ISP for there help and information regarding PPPoE configurations that they require for use.
