jimbomudgie
May 15, 2025Aspirant
RS600 Setup Problems
Hi, I am trying to set up a new Nighthawk RS600 but cannot seem to connect to the internet with it. I have a TPG HFC connection. I'm moving from an Netgear Orbi so I would think it should work. I co...
- Aug 08, 2025
Hi Jim
I hope this reply is not too late for you.
I bought a RS600 recently and had the same problem like you: TPG, CM8200B and RS600. I could not make the RS600 get the internet. Finally, I worked it out.
The solution is
In the webpage RS600 setup menu, choose BASIC-Internet then set
Require a login
Internet Port(10 Gbps)
PPPoE
your TPG username (doesn't need email format, just the name)
password
then leave all other as default
Then go to the bottom of this page, VLAN ID Configuration
Tap VLAN/Bridge Settings, enable VLAN/Bridge group, pick By VLAN tag group, EDIT AND make the VLAN ID to 2.
Apply the setting and hopefully, the RS600 should work.
HankDeng
Aug 08, 2025Initiate
Hi Jim
The solution is
Require a login
PPPoE
password
thankyouhank
Sep 25, 2025Aspirant
TPG HFC + CM8200B + RS600 users, this setup worked for me. Thank you Hank you absolute legend.
