ipg8x's avatar
ipg8x
Guide
Jan 14, 2026
RS700 - 5GHz Wifi - Channel Auto 40
Hello,    I have noticed my wifi 6 (802.11) devices are getting a slower connection around 180mbps, it used to be around 350-450 mbps when performing a speed test.    Upon looking into router con...
  • FURRYe38's avatar
    Jan 14, 2026
    Possible AUTO setting for 5Ghz and the FW system maybe seeing interferences on other channels and picking a lessor noisy channel. Something that the FW systems handles.
    I use channel 40 all the time here. However mostly use 48 on my RS700 as I have other noisy channels near by.
    You don't have to use AUTO setting. Pick something that works best for your environment. Manual works well. Can try the other channels. Pick something that works best for you.
