ipg8x
Jan 14, 2026Guide
RS700 - 5GHz Wifi - Channel Auto 40
Hello, I have noticed my wifi 6 (802.11) devices are getting a slower connection around 180mbps, it used to be around 350-450 mbps when performing a speed test. Upon looking into router con...
- Jan 14, 2026
Possible AUTO setting for 5Ghz and the FW system maybe seeing interferences on other channels and picking a lessor noisy channel. Something that the FW systems handles.
I use channel 40 all the time here. However mostly use 48 on my RS700 as I have other noisy channels near by.
You don't have to use AUTO setting. Pick something that works best for your environment. Manual works well. Can try the other channels. Pick something that works best for you.
morrijas
Feb 06, 2026Tutor
The thing is if looking by the lights the router WiFi is all white means it is good the only light that is orange it the internet light which means no connection, but if you look at the wireless lights on the router my 2.5,5 and 6ghz are all up and white, but my cable modem is 3 years old so Xfinity is coming out to put in newer cable modem Saturday so we see, just in case I have 2 netgear rs700s routers, one being used only 6 months old and 1 still in the box never taken out and is my backup so I guess I will see if this helps on Saturday or not
coolwifi
Feb 06, 2026Luminary
This sounds like an issue with the modem or ISP issue. Hopefully you will find out soon.
