400feetup
Nov 25, 2025Guide
RS700 - Firmware problems ongoing
Firmware version is currently v1.0.9.16 because the updated version v1.0.9.6 basically nuked the router and nothing would connect to the internet. I reverted it back to the v1.0.7.96 version and stil...
400feetup
Dec 02, 2025Guide
UPDATE:
Actually got help from REAL people, which is amazing! So far in the troubleshooting process, the 1.0.9 FW was fairly stable but would not auto-grab DHCP and seemed to lose connection in the middle of the night. Did about an hours worth of troubleshooting and contacted the same person back to let them know the status. Even after updating to the latest firmware (trial i believe) It is still taking an excessive amount of time to get successful DHCP back to the router from the fiber ONT. I am extremely thankful for the netgear staff who are working actively on this issue and escalating as necessary to hopefully get this resolved. In all honesty, a lot of the time it has taken was my fault due to family issues, holidays and work schedules, however, the netgear guys are on it with email updates, suggestions and looking for my results. As a note to anyone else who may be going thru a similar issue, when you perform troubleshooting, open your notepad app and document EVERY STEP. even the menial things may not matter to you but they do to the techs. "Rebooted, waited forever for the router to reboot" Put a time frame in there, if its shouldn't take more than 2-3 minutes and its taking 5+, write it down!
I will keep this updated as progression continues and what the final outcome is.
Dec 02, 2025Guru - Experienced User
Thanks for the update.
Keep working with NG support folk hopefully will get this all fixed.
- 400feetupDec 02, 2025Guide
just a thought, is there a version of firmware that came stock with the RS700 or a firmware version history with dates? I would be thrilled to see the timeline and figure out which one was stock on my router.
- FURRYe38Dec 02, 2025Guru - Experienced User
Can look at previous FW version on the RS700's download site. Though you'll need to download each one as the date seen on the web page isn't acurate or reflecting of actual date of FW released.
I do have and have downloaded those versions listed as well as 3 other sanctioned versions. I am just wondering what version shipped with routers during what time frame. so like April 2025 had version whatever. Thats more what i was meaning.
