400feetup
Nov 25, 2025Guide
RS700 - Firmware problems ongoing
Firmware version is currently v1.0.9.16 because the updated version v1.0.9.6 basically nuked the router and nothing would connect to the internet. I reverted it back to the v1.0.7.96 version and stil...
400feetup
Dec 09, 2025Guide
samHoney
The problem began with the firmware auto update. The version prior to that, I personally had no problems. The problem with reaching out directly to Netgear support, is running into a support paywall when trying to get actual support, wherein Netgears own update breaks the router and now you have to pay them to send you firmware and experiment on it to fix it. This community thread has been the best resource for not only troubleshooting and firmware/beta firmware, but also to discuss specific problems related to firmware updates as well as how other beta/trial firmware have an impact on router malfunctions. It has been and is a well known issue and at this point, i dont understand why netgear has issued an emergency ground stop to any RS700 firmware updates automatically to prevent further failures?
- FURRYe38Dec 09, 2025Guru - Experienced User
Did you get some beta FW from NG support or Engineering?
