omane
Nov 17, 2025Aspirant
RS700 - passing L2TP traffic to internal server
[NOTE: I am preconfiguring an RS700 on my local LAN so I can send it to a remote family member. Hence, the "external" address of the RS700 is a private address (192.168.3.155); the LAN/internal addre...
- Nov 18, 2025
I greatly appreciate the help everyone!
Following StephenB's comment about trying to forward Port 5000 (and 5001 for https administration), I neither worked. Doubtful that it would be a Netgear bug, I went down the path of starting from scratch with the network connectivity. The issue (please don't kill me) is that I had the Synology server connected (via ethernet) to both the 192.168.3.x and 192.168.10.x networks (multiple ethernet ports in the Synology). Once I disconnected the 192.168.3.x ethernet, everything worked as expected.
Thanks for your help! Apologies if this is a rookie mistake...
omane
Nov 18, 2025Aspirant
Thanks.
I'm configuring the RS700 offsite. The R7800 is onsite (a full day drive away) and working properly. Once the RS700 is configured it will replace the R7800. The configurations of both appear to match (IP reservations, port forwarding settings, etc.). The only difference currently is the R7800 is connected to the Internet Modem while the RS700 is on a LAN in a lab.
R7800 config: Internet -> Modem -> R7800 (192.168.10.1) -> Synology (192.168.10.5)
RS700 config: Internet -> Modem -> Router (192.168.3.1) -> RS700 (ext. 192.168.3.155 / int. 192.168.10.1) -> Synology (192.168.10.5)
Test Client connection: Internet -> Modem -> Router (192.168.3.1) -> client machine (192.168.3.151) -> RS700 (ext. 192.168.3.155 / int. 192.168.10.1) -> SynologyTest (192.168.10.5)
My next move is to connect the RS700 to my modem (taking the 192.168.3.* network out of the equation) and testing from the internet.
Nov 18, 2025Guru - Experienced User
omane wrote:My next move is to connect the RS700 to my modem (taking the 192.168.3.* network out of the equation) and testing from the internet.
If I'm right about the cause, that will also fail. As would moving the Synology to the 192.168.3.x network and testing from the internet. Easy to try though.
If you are thinking that port forwarding is the problem, you could try putting the NAS in the RS700 DMZ as a test.
Is there a Synology managing the VPN on site now?
- omaneNov 18, 2025Aspirant
I agree; but it never hurts to rule it out.
I will look at doing that.
Yes. The configuration with the R7800 has been working for years.
