FattiesGoneWild
Jan 19, 2026Guide
RS700 2.4ghz for 20hz channel width only?
I’m not seeing the option any where to do that? I don’t want it in 20hz/40hz mixed and just want 20hz for 2.4ghz band.
- Jan 20, 2026
In the wireless settings, select speed up to 0.7 Gbps (for RS700 router) in the 2.4 Ghz band. This will lock the 2.4 Ghz band to 20 Mhz bandwidth. Not enabling the 20/40 Mhz coexistence with the maximum 1.4 Gbps speed in the 2.4 Ghz band will lock it to 40 mhz bandwidth.
Jan 20, 2026Guru - Experienced User
Unless you're in the country without any other signals, setting your width to 40Hz only hurts you and your neighbors. Because it'll be wider, more networks can cause interference. Plus, because it has to wait for other networks to finish broadcasting or to start broadcasting, it can cause increased latency. And again, not just for you but for your neighbors in the area. So, unless you're in the rare instance of country living, I'd leave coexistence on.
