FattiesGoneWild
Jan 19, 2026Guide
RS700 2.4ghz for 20hz channel width only?
I’m not seeing the option any where to do that? I don’t want it in 20hz/40hz mixed and just want 20hz for 2.4ghz band.
- Jan 20, 2026
In the wireless settings, select speed up to 0.7 Gbps (for RS700 router) in the 2.4 Ghz band. This will lock the 2.4 Ghz band to 20 Mhz bandwidth. Not enabling the 20/40 Mhz coexistence with the maximum 1.4 Gbps speed in the 2.4 Ghz band will lock it to 40 mhz bandwidth.
FattiesGoneWild
Jan 20, 2026Guide
Thank you both! Kinda weird you can’t exclusively set channel width to 20hz only. Other routers allow that.
coolwifi
Jan 20, 2026Virtuoso
You can reduce the 2.4 Ghz speed to set it to 20 Mhz bandwidth only.
