FattiesGoneWild
Jan 19, 2026Guide
RS700 2.4ghz for 20hz channel width only?
I’m not seeing the option any where to do that? I don’t want it in 20hz/40hz mixed and just want 20hz for 2.4ghz band.
- Jan 20, 2026
In the wireless settings, select speed up to 0.7 Gbps (for RS700 router) in the 2.4 Ghz band. This will lock the 2.4 Ghz band to 20 Mhz bandwidth. Not enabling the 20/40 Mhz coexistence with the maximum 1.4 Gbps speed in the 2.4 Ghz band will lock it to 40 mhz bandwidth.
FattiesGoneWild
Jan 21, 2026Guide
coolwifi,
No freaking way! I cannot thank you enough and made the change to 0.7 Gbps forcing 20hz channel width.
coolwifi
Jan 21, 2026Virtuoso
Glad, you found it!
