milkyway12
Aug 27, 2025Aspirant
RS700 400-500 Mbp's Down/ 50 Up
Hello! I really need some help on figuring this out. My router will not, under any circumstances, maintain 1 Gbps up or down speeds. When i reboot the router the RS700 I get 1Gig up and down no p...
Aug 28, 2025Guru - Experienced User
What test site is that?
What are the results with QoS disabled?
milkyway12
Aug 28, 2025Aspirant
https://www.waveform.com/tools/bufferbloat?utm_source=chatgpt.com
After I reboot the router, everything works great for about 10-15 minutes, and it reverts back to those speeds. 400-500 down and 30-50 up.
- FURRYe38Aug 28, 2025Guru - Experienced User
Can try more recent FW version however there other known issues with that version. Or NG has a beta that maybe available to you.
