FattiesGoneWild
Jun 05, 2026Guide
RS700 5ghz wpa2 default?
Had to do a factory reset and running latest firmware version 1.0.11.6 I can’t seem to set on 5ghz band wpa2+wpa3 by itself. It’s greyed out for some reason. I can seem only do it with 2.4ghz band wh...
FattiesGoneWild
Jun 05, 2026Guide
Smart connect is enabled. I was just taken back while using that, it defaults to wpa2 only on the 5ghz side. Unless you change it under 2.4ghz to wpa2+wpa3 which changes it to that for 5ghz as well only then. Why would Netgear not default to wpa2+wpa3 on the 5ghz side?
Jun 06, 2026Guru - Experienced User
Probably to help ensure 1st connection compatibility. Most devices only use WPA2, sans new gen pads and phones. So once users get a router setup, then it's up to them to make the change if they want too. All on the users hands then.
- FattiesGoneWildJun 06, 2026Guide
Makes sense then for optimal compatibility reasons and user friendly setup. I’ve had this router since it first came out. I remember it being set to wpa2+wpa3 by default. Thinking Netgear just made this change with the latest firmware release. 🤷
