firemaguy's avatar
firemaguy
RS700 6GHz band not visible
Have just upgraded my router to RS700s. I can't get my client devices (Samsung Galaxy Z Fold 5 and iPad Pro 11" (gen4)) to connect to the 6GHz band. I'm sure my client devices support Wifi 6E but they just can't find the 6GHz band on the RS700. I've tried to turn Smart Connect on and off, have changed the channels to either PSC or no-PSC channels, still no luck. Is there anything I can try? Thanks.
  • As communicated with firemaguy, per our research, we believe the WiFi client devices do not enable the 6GHz band in that region at this point. Looks the administration for that region just adopted WiFi 6GHz recently.
  • FURRYe38's avatar
    Does any WiFi scanner app show any signals on 6Ghz?
    Does disabling WiFi Security temporarily show anything? Set back to Mixed WPA2/WPA3 modes after checking this.
    Factory reset and setup from scratch?
    • firemaguy's avatar
      firemaguy
      Firmware version is latest 1.0.7.86.
      Modem is Huawei EchoLife HG8040H
      Tried to scan wifi signal across the whole 6GHz band on my mobile, no 6GHz signal could be found.
      I can only disable Wifi security on the 2.4 and 5GHz band, 6GHz one is fixed to WPA3. Still no 6GHz signal if I disable the 2.4/5G Wifi security. Also tried factory reset and setup from scratch. Still no luck.
      • BH_C's avatar
        BH_C
        NETGEAR Expert
        Hi firemaguy, did you set different SSID for different band? if you have done that, can you go to the router's management Web GUI, go to the ADVANCED tab, then get the screenshots for the Wireless Settings (6GHz) like below?
        Thanks.
