jerm1777
May 26, 2026Aspirant
RS700 DHCP Issues with newest firmware
I purchased an RS700 back in February and on the previous firmware I had the slow Wi-Fi issue and once I would login to the web UI and re-apply the Wi-Fi settings it fixed everything and seemed to be...
May 26, 2026Guru - Experienced User
What brand and model# ethernet adapter are you using in your Ethernet PCs?
Issue still happen with protection engine and IPv6 disabled?
Been using newest FW version since day one. No issues seen currently.
DHCP is working for me. Using default 192.168.1.1 however IP address pool range is set to .100 thru .150 for my needs here.
Connected to a CM3000 series cable modem.
Might contact NG support and ask about this. If you have done resets and setup from scratch along with power cycling the ISP modem, possible something with the RS maybe doing bad things.
