jerm1777
May 26, 2026Aspirant
RS700 DHCP Issues with newest firmware
I purchased an RS700 back in February and on the previous firmware I had the slow Wi-Fi issue and once I would login to the web UI and re-apply the Wi-Fi settings it fixed everything and seemed to be...
CrimpOn
May 26, 2026Guru - Experienced User
jerm1777 wrote:showing no internet/IP configuration failure after a reboot
Is that a reboot of individual devices or a reboot of the RS700 router?
jerm1777
That's a reboot of the RS700 router. I have around ~60 devices on my Wi-Fi network at any given time.
- CrimpOnMay 26, 2026Guru - Experienced User
Do any of the 60-odd devices have reserved IP addresses in the LAN Setup table?
Just to be sure we're on the same page, can you describe how the LAN is configured. i.e.
- IP Address
- IP Subnet Mask
- DHCP Starting Address
- DHCP Ending Address
- jerm1777May 27, 2026Aspirant
The LAN is configured like this:
IP Address - 10.31.5.1
Subnet Mask - 255.255.255.0
DHCP Starting address - 10.31.5.2
DHCP Ending address - 10.31.5.254
I do have 5 reservations ranging from 10.31.5.101 to 10.31.5.105. Two of those are printers, two cameras, and my Reolink hub which is plugged in via ethernet. I have had this LAN setup on other routers without issue in the past including a Netgear R7000.
This whole issue happened after a fresh reset before I even set any of this up though using 192.168.1.1 for the IP and 192.168.1.2 to 192.168.1.254 as the range with no reservations setup.
- FURRYe38May 27, 2026Guru - Experienced User
Please try to see if the 192.168.1.1 or a 10.0.0.1 IP address string works and let us know the results.
You might contact NG support and open a support ticket.
If I can get some time, I'll try your IP address configuration on mine and see if I can reproduce anything.
Where and when did you first start using 10.31.5.1 subnet?
I normally use IP address pool range .100 to .200 on my RS700.
Printers, NAS, controllers and a few cameras are all set for static IP addresses ON these devices out side of this pool range. Leave inside the pool for Dynamic and IP address reservations. Which is standard practice.
I've not see any issues with this configuration. Been using this for past 20 years with zero issues.
