jerm1777
May 26, 2026Aspirant
RS700 DHCP Issues with newest firmware
I purchased an RS700 back in February and on the previous firmware I had the slow Wi-Fi issue and once I would login to the web UI and re-apply the Wi-Fi settings it fixed everything and seemed to be...
jerm1777
Jun 06, 2026Aspirant
Do you have an IoT network configured and setup too? I have a lot of devices on that network. The logs seem to indicate a cross-talk issue between the IoT SSID and the main SSID. I am going to try disabling the IoT network at some point this weekend and do a reboot and see if I still hit the issue.
Jun 06, 2026Guru - Experienced User
No, just main WLAN. Several IoT devices online currently.
