jerm1777
May 26, 2026Aspirant
RS700 DHCP Issues with newest firmware
I purchased an RS700 back in February and on the previous firmware I had the slow Wi-Fi issue and once I would login to the web UI and re-apply the Wi-Fi settings it fixed everything and seemed to be...
jerm1777
Jul 09, 2026Aspirant
I got a trial firmware from Netgear support a few weeks ago. I have it installed on my RS700, but I haven't had the chance to actively test it yet. I had been using a Raspberry Pi as a DHCP server in the time being so I need to disable that and test. Hopefully I can get it tested this weekend.
Jul 09, 2026Guru - Experienced User
Sounds good. Hoping it works better.
