Intoxicating
Jun 16, 2026Star
RS700 DNS issues
Hi, I’ve noticed what appears to be DNS leakage in the latest two versions (1.0.11.8 & 1.0.11.6) I use custom DNS for adblocking and with both versions I’ve seen what would normally be blocke...
Jun 16, 2026Guru - Experienced User
Intoxicating wrote:Suspect that after a while the RS700 is using the ISP WAN supplied DNS as well as the custom DNS as the blocking / unblock is random.
Did you confirm this? One way is to use the DNS test at BrowserLeaks.com.
coolwifi is seeing that CloudFlare is being added as a DNS server with the RS500, FURRYe38 is seeing that the "automatic" setting is using Google+CloudFlare, and ignoring the ISP DNS server.
So something odd here, that might also apply to the RS700.
- IntoxicatingJun 16, 2026Star
I’ve got the old working version on at the moment but my ISP (Zzoomm) use Cloudflare and Google as DNS, I use NextDNS.
One.one.one.one appears in my logs with versions 1.0.11.8 & 1.0.11.6 installed but doesn’t with the older.
I was also seeing that on an Adblock test that on the old version I get 98% blocked but on the newer versions it was impossible to get everything blocked that would normally be blocked.
I’m pretty confident the 1.0.11.6 version has introduced the bug.
