DNAComm
Jan 17, 2024Tutor
RS700 Doesn't connect to old devices...why?
Hi all and thanks for taking my question/s into consideration. I'm looking or some assistance as to why my new R700 Router is AWESOME, but not perfect. Backstory - Since the beginning of the p...
- Jan 17, 2024
@ netgear hasn't been used in a while if at all. I don't think that account is used any more.
Can post here:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Or we can tag BH_C
DF11
Mar 22, 2024Aspirant
Could we possibly get a set of radio buttons on the smart connect declaring which bands we'd like it to jump between? I would use smartconnect if bouncing from 5 to 6 but definitely won't use it with 2.4 in the mix. But jumping from 5 to 6 depending on trafffic and signal strength might be useful. I figured the radio button idea would late you use it down the road as more options like ultrawide start showing up do you could offer the same menu option just with more channels depending on a router's capabilities.
Thanks!
