Jack-L-Lantern
Jul 10, 2025Follower
RS700 firmware update 1.0.9.6 breaks Windows Server DCHP
For context, I use Windows Server 2019 DHCP for my DHCP Server, so I disable the DHCP feature on the router. After the 1.0.9.6 update I found that the Windows DHCP Server was broken and gave the erro...
BH_C
Jul 20, 2025NETGEAR Expert
Hi Jack-L-Lantern ,
I just PM you a link for the RS700 trial firmware that fixes the issue. Could you give it a try to see if it fixes the issue on your network? We could reproduce the issue and we have confirmed the trial firmware fixes the issue in our setup.
Thank you.
