DLAUS
Jul 08, 2025Aspirant
RS700 firmware update 1.0.9.6
Hi After upgrading to 1.0.9.6, something has prevented some of my 2.5ghz devices from being able to connect to wpa2/3 setting when smart connect is enabled. the only way to resolve was to ...
Jul 08, 2025Guru - Experienced User
What channels are you using on the router? Try 1 and 40.
Did you factory reset and setup from scratch after v.6 FW was loaded to see if this helps any?
