DLAUS
Jul 08, 2025Aspirant
RS700 firmware update 1.0.9.6
Hi After upgrading to 1.0.9.6, something has prevented some of my 2.5ghz devices from being able to connect to wpa2/3 setting when smart connect is enabled. the only way to resolve was to ...
PumpkinPatch
Jul 08, 2025Guide
Similar problem here. I have a Honeywell thermostat that will not reconnect to the router since the firmware update. I've tried repeatedly to enter the password for the primary network and the guest network and it will not allow the thermostat back in. Hitting the WPS button while submitting the password did not help either. I also had to reconnect a ring camera after the firmware update. This has been a very frustrating update.
- rawintellectJul 08, 2025Apprentice
Have you tried my suggestion? It really did fix it right up for me. Both my Direct TV receiver and my Honeywell thermostat had the problem.
- PumpkinPatchJul 08, 2025Guide
I am interested in trying this suggestion. I'm not very astute on IT matters...if I'm not hardwired to the router, after I uncheck "enable wireless radio" and hit apply, will I still be able to wirelessly connect to the router to recheck and hit apply? In other words, will my computer still be able to log into the router admin panel wirelessly to reject the box? I use a wheelchair it's just not physically possible for me right now to hardwire my device into the router, if necessary.
Sorry I didn't get to you sooner. Yes you will need a wired device to plug into the router to enable the radios again. I see NetGear has already answered this but I didn't want you to think I ignored you. :)
- MickleHSep 07, 2025Tutor
I am having the same problem with my Honeywell Thermostat, Dyson Air Purifier, and an old Sony DVD player. What is your suggestion?
- BH_CSep 07, 2025NETGEAR Expert
For now, please rollback to the previous version, v1.0.7.96
https://kb.netgear.com/000066519/
We will have a trial firmware release fixing the issue on v1.0.9.6 that some devices in some scenarios could not get an IP address, which we believe causes the connection issues reported here. If you would like to try to trial firmware, please let us know. Thank you.
