DLAUS
Jul 08, 2025Aspirant
RS700 firmware update 1.0.9.6
Hi After upgrading to 1.0.9.6, something has prevented some of my 2.5ghz devices from being able to connect to wpa2/3 setting when smart connect is enabled. the only way to resolve was to ...
PumpkinPatch
Jul 08, 2025Guide
Similar problem here. I have a Honeywell thermostat that will not reconnect to the router since the firmware update. I've tried repeatedly to enter the password for the primary network and the guest network and it will not allow the thermostat back in. Hitting the WPS button while submitting the password did not help either. I also had to reconnect a ring camera after the firmware update. This has been a very frustrating update.
rawintellect
Jul 08, 2025Apprentice
Have you tried my suggestion? It really did fix it right up for me. Both my Direct TV receiver and my Honeywell thermostat had the problem.
