DLAUS
Jul 08, 2025Aspirant
RS700 firmware update 1.0.9.6
Hi After upgrading to 1.0.9.6, something has prevented some of my 2.5ghz devices from being able to connect to wpa2/3 setting when smart connect is enabled. the only way to resolve was to ...
jsheehan
Jul 08, 2025Guide
Tried the turning off wireless radios and also doing a factory reset . . . neither worked for ALL me devises (most did work though). The one major one that would not work was MYQ garage door hub. Ended up going back to the previous firmware 1.0.7.96 and now everything is working again. Guess I will just wait for the next update and try that one.
