DLAUS
Jul 08, 2025Aspirant
RS700 firmware update 1.0.9.6
Hi After upgrading to 1.0.9.6, something has prevented some of my 2.5ghz devices from being able to connect to wpa2/3 setting when smart connect is enabled. the only way to resolve was to ...
BH_C
Jul 08, 2025NETGEAR Expert
Thank you all for reporting the issue and the workaround, and we are sorry for the troubles. We will look into it right away.
Once you disable all the radios, all yur WiFi devices will get disconnected, and you need a device wired to the router to enable all the radios again.
PumpkinPatch
Jul 08, 2025Guide
Thank you for the info. Just to give you an update, I installed the previous version of the firmware (1.0.7.96) on my RS 700 and everything is connecting now. I'm not an IT professional but the problems do appear to be related to the most recent firmware update (1.0.9.6).
- PumpkinPatchJul 08, 2025Guide
I just noticed something I'm unclear on: after I downgraded the firmware, I checked the current version and the router displays the current version as 1.0.7.82 both on a web browser and on the nighthawk app.
However, I downloaded and installed the firmware from the zipfile for 1.0.7.96. I went back and rechecked my downloads folder and the file is named RS700-V1.0.7.96_2.0.96.chk. Any idea why it shows up as a much older version of the firmware, 1.0.7.82?
- BH_CJul 08, 2025NETGEAR Expert
Hi PumpkinPatch ,
This is not expected to happen. We will download the firmware from the support site to verify it.
We strongly suggest running firmware v1.0.7.96 or a higher version on RS700. You may leave the RS700 up and connected to the internet for now, the router should upgrade itself to v1.0.7.96 over the night. Thanks.
- Raddip1Jul 09, 2025Guide
I can also confirm similar issues with the latest firmware. My preassigned static ip addresses are being randomly reassigned with no user intervention. It happens all by itself… even overnight. Naming conventions and MAC addresses randomly change.
This is even after several factor resets, reboots, uploading of previous backups etc.
