DLAUS
Jul 08, 2025Aspirant
RS700 firmware update 1.0.9.6
Hi After upgrading to 1.0.9.6, something has prevented some of my 2.5ghz devices from being able to connect to wpa2/3 setting when smart connect is enabled. the only way to resolve was to ...
rawintellect
Jul 08, 2025Apprentice
Sorry I didn't get to you sooner. Yes you will need a wired device to plug into the router to enable the radios again. I see NetGear has already answered this but I didn't want you to think I ignored you. :)
PumpkinPatch
Jul 08, 2025Guide
Oh no worries and yes, I'm all set! Thanks for the reply!
