DLAUS
Jul 08, 2025Aspirant
RS700 firmware update 1.0.9.6
Hi After upgrading to 1.0.9.6, something has prevented some of my 2.5ghz devices from being able to connect to wpa2/3 setting when smart connect is enabled. the only way to resolve was to ...
BH_C
Jul 08, 2025NETGEAR Expert
Thank you all for reporting the issue and the workaround, and we are sorry for the troubles. We will look into it right away.
Once you disable all the radios, all yur WiFi devices will get disconnected, and you need a device wired to the router to enable all the radios again.
DLAUS
Jul 09, 2025Aspirant
I can also confirm downgrading has completely fixed the issue, I'm also not an expert by any means but it does seem to be linked to the new firmware.
