DLAUS
Jul 08, 2025Aspirant
RS700 firmware update 1.0.9.6
Hi After upgrading to 1.0.9.6, something has prevented some of my 2.5ghz devices from being able to connect to wpa2/3 setting when smart connect is enabled. the only way to resolve was to ...
RichardTTT
Jul 23, 2025NETGEAR Expert
Hi,
Just wanted to let you know I’ve sent you a PM with a trial firmware—feel free to let me know if you’ve had a chance to try it out.
We’re continuing to look into the WiFi connectivity issue and really appreciate everyone’s input. If anyone else is seeing similar behavior and would be open to testing a debug firmware, feel free to PM me directly.
Thanks again for all the support!
PumpkinPatch
Jul 23, 2025Guide
Hi Richard,
I responded to your DM a while ago.
