DLAUS
Jul 08, 2025Aspirant
RS700 firmware update 1.0.9.6
Hi After upgrading to 1.0.9.6, something has prevented some of my 2.5ghz devices from being able to connect to wpa2/3 setting when smart connect is enabled. the only way to resolve was to ...
stanfrench
Jul 26, 2025Luminary
I have the same issue with my Honeywell 9000 Series (RTH9580 Wi-Fi) thermostat and La Crosse C83100 weather station. Both are older 2GHz band only devices that worked perfectly before the v1.0.9.6 update. I was able to get them running by linking them to my extender instead of directly to the RS700 router, but that seems to have caused those extenders to lose internet connection. When I change the 2GH band channel assignment (1,7 or 11) on the RS700, the internet connection is reestablished at the extender but usually disconnects after a few hours.
Jul 27, 2025Guru - Experienced User
Please revert to prior working version of FW and wait for next FW update.
