DLAUS
Jul 08, 2025Aspirant
RS700 firmware update 1.0.9.6
Hi After upgrading to 1.0.9.6, something has prevented some of my 2.5ghz devices from being able to connect to wpa2/3 setting when smart connect is enabled. the only way to resolve was to ...
dnatek
Jul 31, 2025Aspirant
Just adding that I've had similar issues once upgrading to 1.0.9.6. My Honeywell thermostat and my GE oven will no longer connect. Not the end of the world but kind of annoying since they worked fine before the update.
RichardTTT
Aug 01, 2025NETGEAR Expert
Hi,
Thanks for your feedback.
I just sent you a PM—please check and let us know if we can gather more information from your case to help us improve.
