DLAUS
Jul 08, 2025Aspirant
RS700 firmware update 1.0.9.6
Hi After upgrading to 1.0.9.6, something has prevented some of my 2.5ghz devices from being able to connect to wpa2/3 setting when smart connect is enabled. the only way to resolve was to ...
jpljr2-0
Aug 04, 2025Aspirant
Same issue here, Honeywell Themostats show on the Router device list, but I cannot connect them to the RS700.... cannot coonect to an IP address. tried all the reset, etc above.... no success. I'd be willing to try Beta also.
- RichardTTTAug 04, 2025NETGEAR Expert
Hi,
Thanks for your feedback.
I just sent you a PM—please check and let us know if the trial firmware works.
