DLAUS
Jul 08, 2025Aspirant
RS700 firmware update 1.0.9.6
Hi After upgrading to 1.0.9.6, something has prevented some of my 2.5ghz devices from being able to connect to wpa2/3 setting when smart connect is enabled. the only way to resolve was to ...
jpljr2-0
Aug 04, 2025Aspirant
Same issue here, Honeywell Themostats show on the Router device list, but I cannot connect them to the RS700.... cannot coonect to an IP address. tried all the reset, etc above.... no success. I'd be willing to try Beta also.
RichardTTT
Aug 04, 2025NETGEAR Expert
Hi,
Thanks for your feedback.
I just sent you a PM—please check and let us know if the trial firmware works.
