DLAUS
Jul 08, 2025Aspirant
RS700 firmware update 1.0.9.6
Hi After upgrading to 1.0.9.6, something has prevented some of my 2.5ghz devices from being able to connect to wpa2/3 setting when smart connect is enabled. the only way to resolve was to ...
SAVANNA425
Aug 07, 2025Aspirant
Yes, you're definitely not alone — I've seen multiple users report similar issues after upgrading to 1.0.9.6, especially with legacy 2.4GHz devices failing to connect when WPA2/WPA3 mixed mode is used alongside Smart Connect.
It seems like the firmware’s implementation of WPA3 is stricter or buggy, and some older devices just can't complete the handshake properly. Disabling Smart Connect or forcing WPA2-only, like you did, is currently the most reliable workaround.
Downgrading the firmware is smart if stability matters more right now. Hopefully Netgear acknowledges this in the next patch. I’d recommend reporting it via their support form or community so it gains visibility.
- FURRYe38Aug 07, 2025Guru - Experienced User
NG is already aware of the issues with v.6 FW. Users can reach out to NG for a beta sample to try or revert back to last working version of FW.
- RichardTTTAug 24, 2025NETGEAR Expert
Hi,
I've sent you a private message—could you please check your inbox when you get a chance?It would be a huge help if we could gather more information from your setup to investigate the WPA2/WPA3 mixed mode issue further. Thanks in advance for your support!
