DLAUS
Jul 08, 2025Aspirant
RS700 firmware update 1.0.9.6
Hi After upgrading to 1.0.9.6, something has prevented some of my 2.5ghz devices from being able to connect to wpa2/3 setting when smart connect is enabled. the only way to resolve was to ...
MickleH
Sep 07, 2025Tutor
I am having similar problems with a few of my 2.4GHz devices (Honeywell thermostat, Dyson Air Purifier, and Sony DVD player). I would be willing to install the trial firmware and report back.
- DarrenMSep 11, 2025Sr. NETGEAR Moderator
Hello MickleH
Did you try reverting to the older firmware?
DarrenM
