DLAUS
Jul 08, 2025Aspirant
RS700 firmware update 1.0.9.6
Hi After upgrading to 1.0.9.6, something has prevented some of my 2.5ghz devices from being able to connect to wpa2/3 setting when smart connect is enabled. the only way to resolve was to ...
ipg8x
Aug 25, 2025Guide
I had issues with the latest firmware 1.0.9.6 breaking notifications on my Eufy cameras (not getting notifications). Once I rebooted the router, the notifications worked for a few days, but then they broke again. Reverting to firmware 1.0.7.96 fixed the issue. I would like to test the trial firmware if it addresses the issue.
RichardTTT
Sep 15, 2025NETGEAR Expert
Hi ipg8x I've sent you a direct message. Please check your inbox.
