LaddieParker
Nov 02, 2025Guide
RS700 IPv4 Lease Not Renewing (still not fixed).
I have a Nighthawk RS700 currently running firmware 1.0.9.16. There is a problem with renewing the IPv4 lease. If I restart the router it picks up an Ipv4 address with a 24 hour lease. After 12 ho...
- Nov 06, 2025
Hi LaddieParker ,
I'm sorry for the late response. As you mentioned, an earlier post reported an issue with the similar symptom, and it's also an ISP in UK. I worked with Intoxicating, who posted that issue, and had the issue fixed. I just PM you the trial firmware v1.0.9.101_25.7.19 which fixes the issue, please give it a try to see if that fixes the issue you ran into.
Thanks.
Nov 02, 2025Guru - Experienced User
Does the ISP required any special WAN connect configurations like PPPoE or is the connection all DHCP?
What CAT# LAN cable is in between the ONT and RS router? CAT6A STP is recommended.
Is Protection Engine enabled on the RS router?
Is IPv6 enabled on the RS router?
Have you tried a Non managed LAN switch in between the ONT and RS router? Seen it where some handshaking between a ONT and router can be resolved with a lan switch in the middle.
LaddieParker
Nov 02, 2025Guide
Thanks for very much your response. My answers in italics
Does the ISP require any special WAN connect configurations like PPPoE or is the connection all DHCP?
No, no special connection just plain old DHCP and both my RS200 and AX6000 work fine.
Cat8
Yes
Yes, and it works fine. It continues to work even when IPv4 drops.
Unlikely, to be the problem as this only started with firmware update 1.0.9.6 and can fixed by downgrading to version 1.0.7.96 but, I'll give it a try.
- FURRYe38Nov 02, 2025Guru - Experienced User
Is the CAT8 UTP or STP? STP is preferred.
Please disable Protection Engine on the RS router.
- LaddieParkerNov 02, 2025Guide
I honestly couldn't say as it is covered with fabric, so you can't read what may be printed on it. However, I have now connected the router to the ONT with the cable that came in the box with the router, which I believe to be the original cable. It does have CAT6 printed on it.
My apologies, I was connected to my RS200 when I said that the protection engine was enabled. Looking at the RS700 there is nothing labelled Protection Engine. There is Online Armour, but that has never been activated.
Many thanks for your help with this. It is much appreciated
Printing should have UTP or STP. If you don't have STP, then it's not STP or Shielded Twisted Pair.
If no PE on the RS700, please try a non managed switch in between the ONT and RS router.
- StephenBNov 02, 2025Guru - Experienced User
Isn't all CAT8 cable shielded?
- CrimpOnNov 02, 2025Guru - Experienced User
Yes, Cat8 cable has shielding on every pair:
This digression about Ethernet cable does not seem germane to the original problem: DHCP Lease not renewing and displaying complete nonsense about the lease.
The RS700 appears to have had three firmware versions released:
1.0.7.76
1.0.9.6
1.0.9.16
Does this lease renewal problem exist with all three versions?
