LaddieParker
Nov 02, 2025Tutor
RS700 IPv4 Lease Not Renewing (still not fixed).
I have a Nighthawk RS700 currently running firmware 1.0.9.16. There is a problem with renewing the IPv4 lease. If I restart the router it picks up an Ipv4 address with a 24 hour lease. After 12 ho...
- Nov 06, 2025
Hi LaddieParker​ ,
I'm sorry for the late response. As you mentioned, an earlier post reported an issue with the similar symptom, and it's also an ISP in UK. I worked with Intoxicating, who posted that issue, and had the issue fixed. I just PM you the trial firmware v1.0.9.101_25.7.19 which fixes the issue, please give it a try to see if that fixes the issue you ran into.
Thanks.
LaddieParker
Nov 10, 2025Tutor
Hi BH_C,
I have been running the trial firmware over the weekend and it seems to have fixed the problem.
Many thanks for your help,
Laddie
Nov 10, 2025Guru - Experienced User
Enjoy. 📡
